  • Andres Cano 22 posts 42 karma points
    Apr 14, 2011 @ 16:00
    Andres Cano
    SendCountourEmail is not working, problem adding new feature to contour
    hi everyone, im having some problem when im trying to add a new workflow to contour, im using the metod here described but is not working for me.
    http://our.umbraco.org/wiki/how-tos/extending-contour,-sending-email-dependent-on-form-selection
    i create a new class and added to the bin folder in umbraco, the code of the class is this one:
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.Core.Enums;
    using Umbraco.Forms.Data.Storage;
    using System.Xml;
    using System.Xml.XPath;
    using Umbraco.Forms.Core.Attributes;
    using umbraco.BusinessLogic;
    namespace SendContourEmail
        public class SendContourEmail : WorkflowType
            // These regions set the fields in for new/cutom workflow you are wanting to create
            [Setting("EmailLookUpField", description = "Enter the receiver email lookup field", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string EmailLookUpField { get; set; }
            [Setting("EmailFrom", description = "Email from field alias that contains email address", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string EmailFrom { get; set; }
            [Setting("Subject", description = "Enter the subject", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string Subject { get; set; }
            [Setting("Message", description = "Enter the intro message", control = "Umbraco.Forms.Core.FieldSetting.TextArea")]
            public string Message { get; set; }
            [Setting("ErrorEmailAddress", description = "Error logging email", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string ErrorEmailAddress { get; set; }
            public override List<Exception> ValidateSettings()
                List<Exception> l = new List<Exception>();
                if (string.IsNullOrEmpty(EmailLookUpField))
                    l.Add(new Exception("'Email Look up field' setting not filled out'"));
                if (string.IsNullOrEmpty(Message))
                    l.Add(new Exception("'Message' setting not filled out'"));
                return l;
            private const string LookUpFieldXpath = "//fields/child::* [caption = '{0}']";
            // Generates the new workflow details for Contour in the workflow dropdown in Contour
            public SendContourEmail()
                // Need to generate a new guid for the new custom workflow - add your own GUID
                this.Id = new Guid("55C192F4-65FB-11E0-8798-CF7DDFD72085");
                this.Name = "Send Custom Email";
                this.Description = "Send Email to the person who fill the form";
            public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
                try
                    RecordsViewer viewer = new RecordsViewer();
                    XmlNode xml = viewer.GetSingleXmlRecord(record, new XmlDocument());
                    XPathNavigator navigator = xml.CreateNavigator();
                    XPathExpression selectExpression = navigator.Compile("//fields/child::*");
                    selectExpression.AddSort("@pageindex", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
                    selectExpression.AddSort("@fieldsetindex", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
                    selectExpression.AddSort("@sortorder", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
                    XPathNodeIterator nodeIterator = navigator.Select(selectExpression);
                    string list = "<dl>";
                    while (nodeIterator.MoveNext())
                        list += "<dt><strong>" + nodeIterator.Current.SelectSingleNode("caption").Value + ": </strong><dt><dd>";
                        XPathNodeIterator values = nodeIterator.Current.Select(".//value");
                        while (values.MoveNext())
                            list += values.Current.Value.Trim() + "<br/>";
                        list += "</dd>";
                    list += "</dl>";
                    string body = "<p>" + Message + "</p>" + list;
                    IEnumerable<string> emails = GetEmailAddressesViaLookUp(xml, body);
                catch (Exception ex)
                    LogError(ex.ToString());
                return WorkflowExecutionStatus.Completed;
            private IEnumerable<string> GetEmailAddressesViaLookUp(XmlNode xml, string emailBody)
                // EmailLookUpField - this is the field which we have specified in the workflow that has the email address
                // values assigned to them, in our case the "Sectors" checkbox list.
                string xpath = string.Format(LookUpFieldXpath, EmailLookUpField);
                string fromEmailXpath = string.Format(LookUpFieldXpath, EmailFrom);
                var addresses = new List<string>();
                XmlNode destiniationIds = xml.SelectSingleNode(xpath);
                XmlNode fromEmail = xml.SelectSingleNode(fromEmailXpath);
                XmlNode emailFromNode = fromEmail.SelectSingleNode("values/value");
                EmailFrom = emailFromNode.InnerText;
                if (destiniationIds != null)
                    // Loops through the the List of emails and sends an email to each department
                    IEnumerable<string> emails = ExtractSectorsFromNodeXml(destiniationIds);
                    foreach (string email in emails)
                        SendMail(email, Subject, emailBody);
                return addresses;
            private IEnumerable<string> ExtractSectorsFromNodeXml(XmlNode destinations)
                var ids = new List<string>();
                XmlNodeList destinationNodes = destinations.SelectNodes("values/value");
                if (destinationNodes != null)
                    foreach (XmlNode destinationNode in destinationNodes)
                        if (destinationNode.Attributes != null)
                            ids.Add(destinationNode.InnerText);
                return ids;
            private void SendMail(string to, string subject, string message)
                var m = new System.Net.Mail.MailMessage
                    From = new System.Net.Mail.MailAddress(EmailFrom),
                    Subject = subject,
                    IsBodyHtml = true
                m.To.Add(to);
                m.Body = message;
                var s = new System.Net.Mail.SmtpClient("localhost");
                s.Send(m);
            private void LogError(string ErrorMessage)
                Log.Add(LogTypes.Error, 0, ErrorMessage);
                if (ErrorEmailAddress != string.Empty)
                    SendMail(ErrorEmailAddress, "Contour custom workflow dmc lookup error", ErrorMessage);
    at the end i only have the workflow form created with this but there is no email sent when i create a new field called email and put an email there to reaply Approved to the person who fill the form
    and this is the image of the created workflow when i acces workflow in the backend of contour
    thanks a lot for any help, i feel lost with this subject.
    IMPORTANT NOTE: the only change that i did in the original code of the class was change "emailAdress" for "email" based on the case that i cant compile the class without having any errors.
    Apr 14, 2011 @ 16:06
    Andres Cano
    to add more info to the problem... the change that i made on the original code of the class, was in the line 120 of the code, and when i add the function to the workflow Approved, and i fill a test of the form, and click Approved on the backend of contour, notthing happened.
    thatnks again for any help with this!
  • Comment author was deleted
    Apr 18, 2011 @ 10:35
    Hi Andres,
    And does the default send email workflow work?
    DO you have a valid smtp sever setup in the web.config + a valid sender email address in the umbracosettings.config?
    Apr 22, 2011 @ 17:07
    Andres Cano
    yes, the default send email is working, but i was trying to setup this in the back end, to cnahged and use it as a template for diferent porpuses, i have a valid smtp server setup, and a valid sender email address in the umbracosettings.config, i just dont know why is not working, thanks again for any help!
  • Jordi Flores 1 post 21 karma points
    Dec 05, 2012 @ 11:53
    Jordi Flores
    Hi Andres,
    Some solution on this?
    I've got the same problem.
    I receive the email sent by "LogError" function, saying "System.NullReferenceException: Object reference not set to an instance of an object" at line 108 and 89 but I don't know why.
