  • DanMann 44 posts 42 karma points
    Apr 19, 2011 @ 13:03
    DanMann
    Data Analysis
    Hello Everyone,
    Does anyone know how I would go about creating graphs and using data from contour for calculations?
    Are there any packages that anyone knows of?
  • Comment author was deleted
    Apr 19, 2011 @ 13:07
    Well you can simply export your data to excell or another tool and then do the calculations you want in that tool. Would that work for you?
    Regards,
    Tim
    Apr 19, 2011 @ 14:55
    DanMann
    Hi Tim,
    That is the easy option.
    I was wanting something that will display at the frontend, a few graphs and totals based on the contour data.
    Apr 19, 2011 @ 14:58
    Hi Dan,
    Well there are some xslt extensions you can use to fetch records and once you have those you should be able to do stuff with the data
    Regards,
    Tim
    Apr 19, 2011 @ 15:02
    DanMann
    Hi Tim,
    Thanks, I am guessing that no one has made a package yet for automatic graphs and charts?
    Dan
    Apr 19, 2011 @ 15:19
    Nope haven't seen one yet
  • Jon Boyer 37 posts 59 karma points
    Aug 08, 2011 @ 04:17
    Jon Boyer
    Check out the Raphael javascript library - http://raphaeljs.com/
    It can grab the contents of tables and turn it into lovely lovely vector graphics (including pie charts and things) on the fly.  Works in all modern browers, and ie as far back as version 5 (!).
