It would be great if you could test the 1.1.8 WIP version to see if it works on medium trust, I've been doing some tests and it looks good so far, but would be great to have someone else test it to make sure everything still works
Done some initial tests on our developement server and seems to run ok in medium trust. Just need to get a test set up at our host to check if it also works in a clustered environment.
Contour and mediumtrust...
Had a problem with mediumtrust in back in Nov 2010, (1.1.3) and at that time had a response that the next maintenance release would address the issue.
Coming back to this now none of the subsequent releases mention mediumtrust support added.
Can you give me an update on whether this has in fact been fixed.
Comment author was deleted
Hi Mike,
This must have slipped under the radar, it has highest priority now and we'll look into this for version 1.1.8
Regards,
Tim
Found a fix for the issue, so you will be able to run Contour on medium trust in a matter of days now
http://nightly.umbraco.org/Umbraco%20Contour/1.1.8%20WIP/
Sorry for the delay...
Perfect, let me know how it goes and if there are any issues popping up (then I'll take care of them).
Tim
