Trigger Approved Workflow using .NET User Control - Corrected
Hi im trying to setup a button in a form named "Click to Approved" to trigger the approved workflow in the back end of umbraco of that record id, for this task i created a form with an editable macro, and im sending the record.id at the end of the form link with ?recordGuid= follow by the record id, taking it using the braket syntax trought the send email.
in the Button User Control i have been using some info related founded in this posts
but i just cant get it work
this is the code of my Button "Click to Approved" User Control
using System;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using Umbraco.Forms.Core;
using Umbraco.Forms.Core.Services;
using Umbraco.Forms.Data;
using Umbraco.Forms.Data.Storage;
using umbraco.BusinessLogic;
namespace UmbracoContourExtendAC
public partial class ApprovedButton : System.Web.UI.UserControl
protected void Page_Load(object sender, EventArgs e)
RecordStorage rs = new RecordStorage();
Record record = rs.GetRecord(new Guid("7ba0a2b0-86d7-4ae0-ad57-d98cc1da5b92"));
RecordService s = new RecordService(record);
if (s != null)
s.Approve();
s.Dispose();
any help will be great, i have been thinking so much in this that is almost driving me crazy...
I'm using pretty much the exact same code for the same thing (but in a /base method) and it's working fine. What exactly is the problem? Are you getting any errors?
The only thing I can think of off the top of my head is maybe the GUID is incorrect? Or the record is already approved?
You should also try to get a more detailed error, maybe by debugging your usercontrol in Visual Studio, making sure you have custom errors set to Off, and maybe checking the umbracoLog table. "Runtime error" isn't too helpful :)
Hi Tom, i check all that but no luck so far, when i debug the user control in visual, everything is fine, maybe i have a loss step in all this process im going to explan you what i have done until now.
the problem: create a button outside the backend of umbraco to approved a form into the same page of the form.
solution:
1. i create a template for a page and insert a macro that render the form with allow editing,
2. i create a macro for a custom button that is going to use a user control to render this button,
Record record = rs.GetRecord(newGuid("7ba0a2b0-86d7-4ae0-ad57-d98cc1da5b92"));
RecordService s =newRecordService(record);
if(s !=null) s.Approve();
s.Dispose();
in the other side i added to the workflow when the form is submitted "send email" and in the body of the email i ad the {record.id} at the end of the link of the rendered form.
ex. <link to the form>?recordGuid={record.id}
now the ideal thing will be, when the person in charge recieved the email just click on the link of the email received, and this will render athe form, with the info of the record, and in the top part there will be a button named "Click to Approved", but what is happening is
1. when i debug the user control in visual everything is fine, after copy the .dll and the user control, and tried to retrieve the page there is a crash on the .net page and the message is Server Error in '/' Application, Runtime Error in
" <!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration> "
2. when i debug the user control in visual comment the part of the code:
s.Dispose();
and copy the .dll and the user control to the bin and user controls folder, and tring to retrieve the web page there is no crash, and the button is rendered well, but of course there is no functionality at all.
i check this thing:
GUIDis ok
Debug in Visual is ok
and i dont have webcongif file to put the custom errors off, i deleted i only have the properties, references, and the user control file in the visual project, but the debug is okey with only that files.
i dont know if i just forget one step or something, again, thanks a lot for your help! i hope all this info can give you and idea.
ohh i just see this error if i access the site in my server side:
The INSERT statement conflicted with the FOREIGN KEY constraint "FK_UFRecords_UFForms". The conflict occurred in database "intranet", table "dbo.UFForms", column 'Id'.
The statement has been terminated.
Exception Details: System.Data.SqlClient.SqlException: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_UFRecords_UFForms". The conflict occurred in database "intranet", table "dbo.UFForms", column 'Id'.
Source Error:
Stack Trace:
[SqlException (0x80131904): The INSERT statement conflicted with the FOREIGN KEY constraint "FK_UFRecords_UFForms". The conflict occurred in database "intranet", table "dbo.UFForms", column 'Id'.
The statement has been terminated.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +2030802
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5009584
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2275
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +215
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +987
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +178
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +137
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(SqlConnection connection, CommandType commandType, String commandText, SqlParameter[] commandParameters) +56
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) +83
umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteNonQuery(String commandText, SqlParameter[] parameters) +21
umbraco.DataLayer.SqlHelper`1.ExecuteNonQuery(String commandText, IParameter[] parameters) +85
[SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery]
umbraco.DataLayer.SqlHelper`1.ExecuteNonQuery(String commandText, IParameter[] parameters) +140
Umbraco.Forms.Data.Storage.RecordStorage.InsertRecord(Record record, Form form) +763
Umbraco.Forms.Core.Services.RecordService.() +192
Umbraco.Forms.Core.Services.RecordService.Approve() +89
UmbracoContourExtendAC.ApprovedButton.Page_Load(Object sender, EventArgs e) +221
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +91
System.Web.UI.Control.LoadRecursive() +74
System.Web.UI.Control.LoadRecursive() +146
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
Does anyone know the fix for error: The INSERT statement conflicted with the FOREIGN KEY constraint "FKUFRecordsUFForms". The conflict occurred in database "intranet", table "dbo.UFForms", column 'Id'.
The statement has been terminated. ?
Please ignore this request. Its issue with Contour. When you delete the record, it automatically does not refresh the screen, but actually it has physically deleted the record. So, user tries to delete the same record again, but actually this time record is not there in database and you see this error / exception.
-Tom
Well basically im getting a
Runtime Errorr when i debug the user control, creating the .dll and put it on the bin folder,
but the User control Works fine when i comment this part of the code
if (s != null)
s.Approve();
s.Dispose();
and the page dont crash and the button "Click to Approved" is rendered, but otherwise without comment that part everything stop working
if (s != null)
s.Approve();
s.Dispose();
thanks a lot for your help I really appreciate it!
sorry for the double post, i was trying to copy the code to show you
-Tom
solution:
this is the code for the template:
<asp:Content ContentPlaceHolderID="ggblank" runat="server">
<br/><br/>
<umbraco:Macro Alias="ApprovedButton" runat="server"></umbraco:Macro>
<umbraco:Macro FormGuid="a30ce693-1201-456d-9f67-7c2611eb9786"
AllowEditing="1"
Alias="umbracoContour.RenderForm"
runat="server">
</umbraco:Macro>
</asp:Content>
the code for the user control is
<asp:Button ID="button1" runat="server" Text="Click to Approved" />now the .cs code of the user control
<configuration>
<system.web>
</system.web>
</configuration> "
i check this thing:
GUID is ok
Does anyone know the fix for error: The INSERT statement conflicted with the FOREIGN KEY constraint "FKUFRecordsUFForms". The conflict occurred in database "intranet", table "dbo.UFForms", column 'Id'. The statement has been terminated. ?
I am trying to delete the record from CMS Contour. but getting error with the page call: http://website.com/umbraco/plugins/umbracoContour/webservices/recordActions.aspx?form=11df48d9-23b0-4ed9-9eaa-0f3bc181c744&record=cae52214-6d77-4165-82e5-d2b4e1486dbc&action=cb126b76-9011-11df-a4ee-0800200c9a66&_=1500087606989
