Hi, I'm using the cultivRestContour package to submit my forms with AJAX. I can see using the provided examples in the package that you can submit forms using field names/ids like "Name", "Email" etc as opposed to the generated ID which is something like: "ContentPlaceHolderDefault_RenderForm_1_rpFieldsets_rpFields_0_label_0"
Is it possible to render all of the "readable" name's/ids of a form? The form i'm working with is way to complicated for trial and error.
Name / ID of contour input fields
Thank you!
Amir
Comment author was deleted
Hi Amir,
Well you could simply check what cultivRestContoru expects (think it will be the field name) and then write a simple export
Tim
