My organisation purchased Contour over a year ago for the purpose of securely capturing skills data for all employees. It's turned into a massive form of 20 pages and hundreds of columns... and Contour seems very unhappy about it!
When I click on the form in Contour I receive the script timeout alert, and whether I choose yes or no to stop running scripts it will eventually load the form. It's irritating, but also might be having a couple of even more inconvenient knock-on effects:
1. When you try and access the form as a user the form loads slowly and shows a page with only the 'previous' and 'next' buttons. Clicking 'previous' will take you to the start of the form.
2. I cannot view any entries. When I select the option to look at entries it sticks on 'Processing...' and seems to crash.
Does anyone know how I can get this to work? I'm hoping to get the Umbraco version upgraded soon, and wonder if that will solve it - but we're having trouble getting the deployment work booked in. Any help is much appreciated!
Version Information: Browser:IE8 Umbraco Version:4.0.3 Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3053
Stop running this script alert
Use Firefox and that issue goes away. If adamant about using IE, then click No on that pop up box.
Hope that helps
