Hi All,
I come up with a situation where i need to select a field in contour using querystring value. Any help/guidance in this regard would be highly appreciated.
Regards,
Zohaib
Comment author was deleted
Hi Zohiab,
What do you mean with select? Or did you want to set the value from the querystring?
Upload image
How to select field in contour using querystring
Hi All,
Regards,
Zohaib
Hi Zohiab,
