  • psiho 101 posts 96 karma points
    May 24, 2011 @ 16:09
    psiho
    contour form templates and custom prevalues/workflows
    We created few custom prevalues and custom workflows, then applied it to an form and exported it. Coped the file to "templates" folder and template was there.
    However, when form is created from that template prevalues are back to defaults and custom workflow is not there. I noticed in export file there are all zeroes in PreValueSourceId, tried entering manually a prevalue id but we no success.
    Are we doing something wrong or this is a bug?
    May 26, 2011 @ 11:02
    psiho
    anyone? This pretty much renders contour templates unusable when you have many custom prevalues :(
  • Bjørn Arild Mæland 2 posts 22 karma points
    Dec 30, 2011 @ 14:03
    Bjørn Arild Mæland
    This is an issue for us as well, especially the lack of workflows in templates..
  • Frank Schjelderup 9 posts 29 karma points
    May 21, 2012 @ 15:56
    Frank Schjelderup
    Have the same issue now, in our case it is a simple dropdown that looses its custom prevalue connection. (Using Umbraco 4.7)
