  • Viral Shah 32 posts 61 karma points
    May 24, 2011 @ 22:21
    Viral Shah
    extend checkbox data type and mandatory requirement
    I am trying to create check box control field data type from contour check box and having problem with Mandatory field set up.
    When i add this new data type on form with Mandatory requirement ON - i get this below error when i try to run the form which has this control.
    Control 'b1998910_dd75_4dc2_bf58_563b5779dfca' referenced by the ControlToValidate property of 'mandatory' cannot be validated.
    This is my full code for the extension. Please help. Thanks in advance.
    namespace CheckedCheckBox.FieldType
        public class CheckedCheckBox : Umbraco.Forms.Core.FieldType
            public Control.CheckedCheckBox chkCheckBox;
            public List<Object> Value;
            public CheckedCheckBox()
                Id = new Guid("1A78EF46-E782-461C-AA6B-E6C30D9746B9");
                Name = "Check box - default Checked";
                Description = "Check box with default checked";
                Icon = "checkbox.png";
                DataType = FieldDataType.Bit;
                chkCheckBox = new Control.CheckedCheckBox();
                Value = new List<object>();
            public override WebControl Editor
                get
                    return chkCheckBox;
                set { base.Editor = value; }
            public override List<Object> Values
                get
                    if (chkCheckBox.Checked)
                        Value.Clear();
                        Value.Add(true);
                    else
                        Value.Clear();
                        Value.Add(false);
                    return Value;
                set { Value = value; }
            public override string RenderPreview()
                return "<INPUT TYPE=\"checkbox\" id=\"check-CheckBox\" checked />";
            public override string RenderPreviewWithPrevalues(List<object> prevalues)
                return RenderPreview();
            public override bool SupportsRegex
                get { return true; }
