I need an OLEDB-Provider for MySQL. Is ist possible with Umbraco? I have installed MyOleDB, but I know how to go no more, I have no idea....
Thank you for any hint!
Gruß
Volker
Comment author was deleted
Well propably you'll need a custom datasource type that works with that provider, should be a simple update of the existing one,
you can download the sourcecode of the existing one here: http://our.umbraco.org/projects/developer-tools/umbraco-contour-shared-source
Thank you!
How do I set up OLEDB for MySQL
Gruß
Volker
Thank you!
Volker
