  • dominik 711 posts 733 karma points
    Jul 05, 2011 @ 09:31
    dominik
    Set sender of emails
    Where can i set the sender of the emails? Can this set for each form or is Contour using the same sender email address for all forms?
  • Comment author was deleted
    Jul 05, 2011 @ 13:12
    Well that's done in the /config/umbracosettings.config file.
    So it will be a single sender for all emails.
    If you wish to have a seperate sender you'll have to modify the workflow type (check shared source code to get started).
    http://our.umbraco.org/projects/developer-tools/umbraco-contour-shared-source
    OR try the contour contrib project maybe they have a workflow that makes it possible to set the sender
    http://our.umbraco.org/projects/developer-tools/contour-contrib
    Tim
  • Anders Brohäll 295 posts 561 karma points MVP c-trib
    Jun 27, 2013 @ 13:29
    Anders Brohäll
    Is the answer still the same?
    Jun 27, 2013 @ 13:30
    Nope if you use latest stable 3.0.12 you can override the sender email from the workflow settings :)
    Jun 27, 2013 @ 13:31
    Well actually has been added since v 3.0.8
    Jun 27, 2013 @ 13:32
    Anders Brohäll
    Damnit. I'm using 3.0.7 :/
    Jun 27, 2013 @ 14:16
    Well you can simply upgrade the providers assembly that should just be an xcopy of a single file (or maybe 2)
    Download the update archive here http://nightly.umbraco.org/Umbraco%20Contour/Archive/3.0.8/
    And all you need is the Umbraco.Forms.Core.Providers.* files found in the bin dir
    Or you can perform a full upgrade to the latest stable for that check out the docs here
    http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    Anders Brohäll
    Got it.
    Thanks!
    Jun 27, 2013 @ 14:17
    No prob glad I could help :)
