  • Tom 713 posts 954 karma points
    Jul 08, 2011 @ 03:42
    Tom
    Custom Validation
    Hi All,
    we're looking to use contour for a competition entry form. The problem is we need to have quite a bit of custom validation like one entry per email address.. validate a barcode number and other things on the server side..
    Is there any provision for extending contour's validation or adding something in a workflow for a custom validation step on the server side?
    Tom
    Jul 08, 2011 @ 11:15
    Sebastiaan Janssen
    That sounds possible, you'll have to write some of your own stuff though. Check out the Contour Contrib project (would love more contributions) and the Contour Shared Source.
  • micagordon 5 posts 54 karma points
    Apr 16, 2015 @ 11:43
    micagordon
    How did you solve it ultimately? Hope you can share your solution.
        add bar code in .net application                           java bar code add-in
    Best regards.
    Micagordon
