Can someone tell me what the limitations are of having TRAIL contour installed?
I know you can't save data, but will it send e-mail for example?
Thanks Ayo
Comment author was deleted
Hi Ayo,
Yes the only limitation is that it will save some placeholder text for all entries but all other functionality (like sending mails ) should work.
Regards,Tim
Upload image
Limitations of trial
Thanks Ayo
Hi Ayo,
Regards,
Tim
