I am using umbraco 4.7 in my local environment , and made the umbraco setup as a virtual directory and used it. Everything went fine.
When i tried install contour(1.1).I got an error that it is seraching for installer.ascx in usercontrols folder instead of umbraco\usercontrols folder.Is there any workaround for it?
The file '/Umbraco/usercontrols/umbracoContour/Installer.ascx' does not exist.
Exception Details: System.Web.HttpException: The file '/Umbraco/usercontrols/umbracoContour/Installer.ascx' does not exist.
Source Error:
I downloaded the contour package and added it through: Developer/Packages/Umbraco package repository/install local package
all seemed fine, but then I got the following conflict:
"Macro Conflicts in the package!
Read more...
This package contains one or more macros which have the same alias as an existing one on your site, based on the Macro Alias.
If you choose to continue your existing macros will be replaced with the ones from this package. If you do not want to overwrite your existing macros you will need to change their alias.
The Macros in question:
Insert form from Umbraco Contour (Razor) (Alias: umbracoContour.RazorRenderForm)
Insert form from Umbraco Contour (Usercontrol) (Alias: umbracoContour.RenderForm)
I've proceeded with the instalation as I couldn't find neither umbracoContour.RazorRenderForm nor umbracoContour.RenderForm,
when I got my exception again: could not load 'Umbraco.Forms.References, Version=1.0.10920.32880, Culture=neutral, PublicKeyToken=null', file not found ..
contour installation error
Hi all,
Comment author was deleted
Yes 1.1 didn't support virtual directories, byt if you install the latest version it should work:
http://our.umbraco.org/projects/umbraco-pro/contour
I get the same error, even when i download last version. Try to install from repository neither from local package
My umbraco version: 4.7.1
contour version: 1.1.11 nad 1.1.8
System: Windows Server 2008 R2 Enterprise
Error code : [HttpException (0x80004005): The file '/umbraco/usercontrols/umbracoContour/Installer.ascx' does not exist.]
Seems that instalation proccess cant create directories/files, but i grant full control for pool in IIS
Is there any other way to install contour ?
I'm also getting the same error
Server Error in '/Umbraco' Application.
Source Error:
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
previously I had installed umbraco with it's default settings, and I was able to install contour forms.
currently I'm working on umbraco that is installed in an IIS virtual directory. and now that I need to install contour form Umbraco.Pro,
I get an YSOD with a System.IO.FileNotFoundException for Umbraco.Forms.References.dll
I belive this link might have a clue to solving my issue: http://our.umbraco.org/m?mode=topic&id=28174
as it titles "umbraco.forms.reference missing" but the link does not open.
has anyone encountared this issue?
regards,
vic.
Hey Vic,
Looks like a file might be missing, could you try a manual install
Details here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Manual
Hi Tim,
Read more...
looking for a way to solve it..
vic.
Can you check if the Umbraco.Forms.References.dll file is in your bin dir
Hi Tim,
looking at \bin directory, the file is not there
my guess is, Umbraco.Forms.References.dll is being requqested during instalation, when the file is not ready.
on the other hand, I have the following files:
Umbraco.Forms.CodeFirst.dll
Umbraco.Forms.CodeFirst.pdb
Umbraco.Forms.Core.dll
Umbraco.Forms.Core.Providers.dll
Umbraco.Forms.Core.Providers.pdb
Umbraco.Forms.Mvc.dll
Umbraco.Forms.Mvc.pdb
Umbraco.Forms.UI.dll
Umbraco.Licensing.dll
and the usercontrols:
EditForm.ascx, Installer.ascx, RenderForm.ascx
from my previous contour instalation (with umbraco default settings)
apply the config and database changes as listed in the link you gave me (http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Manual)
then the "instalation" in theory should work? ;-)
Yeah perform a manual install, do an xcopy of the manual install package and the file should be there
Some steps might already be done, so just go trough the entire list http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Manual
