  • jayanthi 66 posts 86 karma points
    Jul 13, 2011 @ 11:13
    jayanthi
    Umbraco Contour questions
    I have a few questions,can some one put some light on those.
    I am populating comments entry form (contour form),I am success ful in saving the filled entries in database as well as entries in umbraco.
    1. I am using datasource inorder to interact with db.Is there any other way i can interact with db apart from this option when using contour form.
    2. I need to use my contour form on various pages of my site  and i want to use the same contour form on all pages
    and collect the comments related to the product specified in the page.Is there a way to capture from which page this form is submitted so that i can categorize the
    comments.(when using datbase driven contour form)
    3. Can i add more fields other than columns in the table when using databse driven  contour form
  • Comment author was deleted
    Jul 13, 2011 @ 11:53
    1) you could create a custom workflow type that interacts with the db
    2) Contour will store the page id bu default on each record
    3) Not when using a datasource then they are linked, but with a workflow that should be possible
