  • dominik 711 posts 733 karma points
    Jul 18, 2011 @ 14:19
    dominik
    ReCaptcha Problem
    Ive downloaded the latest umbraco contour (i am using umbraco 4.7) and it is working. But everytime i add the two words of ReCaptcha plugin the form is not submitted.
    If i remove ReCaptcha it works.
    Is there any problem with latest version and ReCaptcha?
    Jul 18, 2011 @ 14:23
    Sebastiaan Janssen
    Funnily enough, if Recaptcha is set to mandatory, it won't work. But if it's not mandatory, it will still force you to enter the correct words and it should work.
    Jul 18, 2011 @ 14:24
    dominik
    Yes it is forcing me to input something but everytime i insert the two words the form is not send - i tryed it now 20 times I think.
    I think there is still a problem with umbraco 4.7?
    Also how can i set it to mandatory so it is validated in the validation summary?
    Jul 18, 2011 @ 14:28
    Sebastiaan Janssen
    In your form definition you can make any field mandatory, right? But that was my whole point, it won't work with Contour for some reason, it has to be non-mandatory to make Recaptcha work.
    So if the mandatory checkbox is already off now, I don't know what's going on, I haven't used Recaptcha in Contour for a long time.
    Jul 18, 2011 @ 14:31
    dominik
    Yes it is a non-mandotary field but each two word i insert it always look he is not able to validate it.
    Can someone please also test with Umbraco 4.7?
    Is there another spam protection for Umbraco Contour forms?
    Jul 20, 2011 @ 09:04
    dominik
    If i enter a invalid name there is a message that the word does not match. If i insert it correct the message disapperars but i am not able to submit the form.
    Can someone of the Contour Core team please help?
    Jul 20, 2011 @ 09:28
    Sebastiaan Janssen
    The best way to get support for this is to raise a support ticket: http://umbraco.org/help-and-support/customer-area/contour-support-and-download/contour-helpdesk
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Nov 08, 2012 @ 12:47
    David Brendel
    Hey everybody.
    Got the same problem as the Thread Creator.
    Got two projects with Contour. On one project ReCaptcha is working fine. On the other not.
    Tried to reinstall Contour, tried to update to version 1.1.13 from 1.1.12 and also tried to reinstall Contour Contrib.
    Nothing solved the problem.
    I´m using Umbraco 4.7.2 on the project where it isn't working.
    Any suggestions?
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Nov 19, 2012 @ 10:16
    Jeavon Leopold
    Hi David,
    I have just been working on a new version of Contour Contrib which included a updated reCaptcha, would you be interested in beta testing it? You can get the source code from http://contourcontrib.codeplex.com/SourceControl/list/changesets or I could send you a package installer if that's easier?
    Regards,
    Jeavon
