I just bought a lincense for Contour and when trying to Install the package from the Umbraco Repository I get this error message
No connection to repository. Runway could not be installed as there was no connection to: 'http://packages.umbraco.org'
Now when I install it by choosing the Local Package, yet again i get an error message
Datatype could not be installed + System.NullReferenceException: Object reference not set to an instance of an object.
at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e)
Hi Tim, what is really weird is its working when i view it in my browser. But on the other hand the client would like to be able to virew the form, and i would like to be able to remove the Header repeating itself.
What do i need to configure on the macro to render it properly in editor?
Error when installing Contour
Hi Guys,
System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e)
Any thought on this please?
//fuji
Comment author was deleted
Looks like one 1 part of the installation failed, can you see the contour section?
You can install the datatype manually, it's basicly just creating a new datatype and setting the render control to 'form picker'
Tim
Hi Tim,
Yes i can see the contour section and already added the Lic to the bin folder as well.
Tim, I seems to be missing a macro. When i try to insert the macro in RTE it is telling me that No Macro content is available for the WYSIWYG.
//fuji
Well that just a setting on the macro, on each macro you have a setting render in editor
