  • Fuji Kusaka 2203 posts 4220 karma points
    Aug 11, 2011 @ 21:56
    Fuji Kusaka
    Filtering a comment
    Hi all,
    When adding a workflow in contour To Perform filtering, I cant preview any of Submitted forms even if nothing matches what has been entered in the field Dirty Words.
    What i would like to do, i very simple but cant get it to work though.
    1. Perform a filtering
    2. Send an email to admin to get notify of new comment
    3. Approving the comment .
    However when i opened my Entries, I cant see any of the comments submitted.  Hav a i missed a step somewhere on Contour?
    //fuji
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Aug 15, 2011 @ 12:58
    Tim
    Not sure. There is a "perform filtering" workflow that ships with Contour. The source for it is in the Contour shared source package in the projects section. You could have a look at the source for that and see how that does it to see if you've missed anything in your workflow?
    Aug 21, 2011 @ 18:59
    Fuji Kusaka
    Hi Tim,
    Well if you want to check for lets say Rude words you can also add a new workflow before Submitting a form in contour. I try it but am losing all the data being entered by the user in the form.
    What i  want is to make a Comments form and to this be able to control all the post, instead of displaying the content directly, check for swearings or any rude word which you can add in a list in the workflow.
    Then i will be the Admins choise to allow the display of the comment manually. I did set all these but i just lost all data.
    //fuji
