I have created a contour form,this form is not getting submitted when i have assigned a host name to it's parent content node and the form works fine when placed in other node under content node with different host name.
Can any one throw some light on this
One more question ,
Do i need to use script manager when using a contour form?
I found a exception logged to umbracolog table which shows "Umbraco.Licensing.Exceptions.InvalidLicenseException" and only a few domains approved for it.Is this a problem for my contour form not working in specific domains
One more question
I am facing 'sys ' is undefined ,'Type' undefined ,'Umbraco' undefined for the page containing contour form.How can i fix these errors?
Form not submitting data
hi guys,
One more question ,
Comment author was deleted
Are both test using the exact same form / template ?
If there isn't a script manager on the page Contour will add one so you don't have to add one manually.
Tim
Hi Tim,
One more question
It's license issue.Problem solved
