I found a exception logged to umbracolog table which shows "Umbraco.Licensing.Exceptions.InvalidLicenseException" and only a few domains approved for it.Is this a problem for my contour form not getting submitted in specific domains
One more question
I am facing 'sys ' is undefined ,'Type' undefined ,'Umbraco' undefined for the page containing contour form.How can i fix these errors?
What version of umbraco are you running Contour on?
FOr the invalid domains, you'll need to update your license with the additional domains. Please get in touch here and provide the details of what domains are currently supported and which ones you want to add http://umbraco.com/contact/send-us-an-email
Hi guys,
One more question
Comment author was deleted
Thank you Tim,Will update the license.
I had a question,Is there a way to purchase contour for all the domains running under one umbraco installation,instead of updation on domain based?
