  • Gudmund Berggren 7 posts 27 karma points
    Aug 29, 2011 @ 22:20
    Gudmund Berggren
    Google AdWords Conversion without loading a thankyou page
    Hi!
    I would like to make Contour execute the Google conversion tracking code when a form has been submitted.
    The thing that makes this a bit complicated is that I do not want a separate thank you page. So far so good, but the challenge is where to put the conversion code.
    Can anyone give me a hint?
    Parts of the code that shall be executed is shown below and since no page is loaded/reloaded I am a bit lost.
    <!-- Google Code for .. Conversion Page -->
    /* <![CDATA[ */
    var google_conversion_id = xxxx ;
    var google_conversion_language = "sv";
    var google_conversion_format = "2";
    var google_conversion_color = "ffffff";
    var google_conversion_label = "xcxc";
    var google_conversion_value = 0;
    if (100) {
    google_conversion_value = 100;
    </script>
    <script type="text/javascript" src="http://www.googleadservices.com/pagead/conversion.js">
    </script>
    <noscript>
    <div style="display:inline;">
    <img height="1" width="1" style="border-style:none;" alt="" </div>
    </noscript>
  • Comment author was deleted
    Aug 30, 2011 @ 09:23
    Well binding it to the form submit button would be the obvious option.
    Aug 30, 2011 @ 13:48
    Gudmund Berggren
    Could you indicate in which file this modification can be done ?
    Best Regards
    Gudmund
  • Jeavon Leopold 3074 posts 13632 karma points MVP 11x admin c-trib
    Oct 07, 2011 @ 11:26
    Jeavon Leopold
    It's a bit tricky, but you can do it by using jQuery to append a Iframe with a src loading a page containing the Conversion code.
    We use a altTemplate to keep it neat, call your template something like iframetracking
    <%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %>
    <asp:Content ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server"><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-GB" lang="en-GB">
    <head>
    </head>
    <body>
    /* <![CDATA[ */
    if (100) {
    </script>
    <script type="text/javascript" src=www.googleadservices.com/pagead/conversion.js"
    </script>
    <noscript>
    </noscript>
    </body>
    </html>
    </asp:Content>
    Then in the settings of the form in the "Message on submit" box add the following:
    $('<iframe src="'+document.location.href+'?altTemplate=iframetracking" width="0px" height="0px"></iframe>').appendTo($('body'));
    </script>
    Oct 07, 2011 @ 11:32
    Jeavon Leopold
    Forgot to mention you need to have jQuery included in the head of your page.
    Oct 07, 2011 @ 18:41
    Gudmund Berggren
    Hi!
    Great. Thank you very much ;-)
    Best Regards
    Gudmund
  • Pushpendra Singh 61 posts 116 karma points
    May 01, 2014 @ 06:04
    Pushpendra Singh
    Hi All,
    You are having any  idea/implementation about AdWords like Google in umbraco site.
    Regards,
    Pushpendra Singh
