I have a recent install of contour runing and all seems fine apart from the drop downs with preset values which seem to be set more than once.
It seems like it is populated for the number of times that form has been loaded since the application start.
Any ideas? directions?
Thanks!
Anyone else seen or experiance this? :(
Found the config file and now disabling the form from caching.
This prevents the values being added to the values which are in place.
Not 100% sure of the versions being used, but the config files say Umbraco version 4.7.0 , contour 1.1.9
Upload image
drop downs with duplicate values
Thanks!
