  • Mysterious 27 posts 47 karma points
    Sep 15, 2011 @ 10:16
    Mysterious
    Bracket Syntax default values for drop
    I have a Contour form which contains a dropdown populated from prevalue source "Rating" it has the following values (#Good, #Medium, #Bad), it works just fine.
    but I have a similar form to edit the documents created by the first one, and it has the same field a dropdown with prevalue source "Rating" and in the default value I am putting [#rating] which is the alias of custom property in the doucment type, unfortunately it doesn't show the selected value, it remain empty instead. and to make sure I added a textfield with the same default value and it shows the correct value.
    any ideas?
  • davelane 29 posts 73 karma points
    Sep 29, 2011 @ 18:02
