  • Rajeev 126 posts 154 karma points
    Sep 15, 2011 @ 14:29
    Rajeev
    Is there a way to have optional Steps in Contour form?
    Is there a way to have optional steps in contour forms.
    For.eg:
    I have 10 Fields to Populate in a form and I have a check box for optional step.
    If I check that checkbox, another set of Fields(Mandatory as well) should be displayed for the enduser to Fill out.
    Do Contour support these sort of things now or any packages available to meet the same?
    Please let me know.
    -Rajeev
  • Comment author was deleted
    Sep 19, 2011 @ 13:17
    Currently there isn't any UI in Contour making this possible, however by adding some additional code it is possible
    Sep 21, 2011 @ 07:24
    Rajeev
    hi Tim,
    Thank you for the update.   If you have any sample code available in this regard please let me know.
    Thanks again,
    Rajeev
  • Simon Dingley 1474 posts 3451 karma points c-trib
    Jan 31, 2012 @ 12:41
    Simon Dingley
    Hi Rajeev / Tim - did you progress any further with this?
