I have installed contour several times and never experienced any problem. Now i´m hosting a web at binero and and contour refuses to read/accept the licence file. It only says that contour is in trial mode
Could this be a cache problem? Or could it me mime typ problem?
Im guessing binero hosting is the problem. I made a copy of the web to a VPS and pointed the licensed domain to that in my host file. Then its working just fine.
umbracoForms.lic in place but still in trial mode
I cant think of any other problem.
/ Lars
Comment author was deleted
Sounds like it isn't finding a license file, could you try adding the appsetting contourLicense with the full path to the license file
Tried adding it like this:
<add key="contourLicense" value="~/bin/umbracoForms.lic" />
But still the same
I tried to delete the license file and then putting it in place with the form on the dashboard inside umbraco/contour
Print screens:
Image 1
Image 2
Image 3
Could you try updating the licensing assembly ? You can get it here:
http://nightly.umbraco.org/umbraco.licensing/
That did not help :(
Any ideas what binero could do to make this work?
