Backend not showing content after upgrade to 4.7.1
Just upgraded to Umbraco 4.7.1 and checked my Contour Forms in the Backend but the Forms will not be shown. The Forms are rendered on the frontend, but I can't edit them in the backend anymore. See the screenshot:
I had the same problem, then I upgraded Contour, now when I create a new form it Fails to Save it even if I don't add or make any change.
I thought it may have been an issue based on my connectivity, so I tried it on another installation of our site and got the following message;
The create dialog for "forms" does not match anything defined in "~/umbraco/config/create/UI.xml" this could mean an incorrectly installed package or a corrupt file.
These two sites are identical, exceptr for where they are located. Both cases are running in localhost.
Actually, it is the same thing that the original poster was having issues with. I have a few screen comps. We are running Umbraco 4.7.1 and our contour package is 1.1.4.
It looks like the form it self is not showing up in the admin section. The workflow and entries showed up. Looks like my browser title also states "Undefined".
This is happening on all the forms we prevously had.
The create also isn't working. We are getting a server error runtime error.
Reboot on server and client does not work.
Any ideas?
Thomas
Comment author was deleted
You'll need at least Contour 1.1.10 if you are running Umbraco 4.7.1 (due do a jquery upgrade)
Thx mate, didn't catch up your tweet today
Thomas
Where do I find the 1.1.10 upgrade file?
I've been looking here: http://our.umbraco.org/projects/umbraco-pro/contour but can only find the package-file...
It's available on that page, at the bottom on the source code tab
Ahh... thanks a million Tim... didn't realise that I was looking for "source code"... :o)
Best regards,
Michael
We just got the same thing to happen on ours. It says we have 1.1.4 and it still is not working.
Should I re-install the Contour package?
@Carlos what isn't working? The create ?
Thanks again for the help.
Any help is appreciated for my last post.
