I agree they are old things from the CWS package, but i didn't installe the CWS package, and if you look at page 7 in the installation guide for the manual installation of Umbraco Contour 1.1.8 is says to add the sections in the dashboard.config.
I presume it gets added aswell in the automatic installation package
Missing Usercontrol in package
Hey Contour People
After I installed Contour on my solution, I get som errors in umbraco.
I know it is pretty straight forward just to delete the settings in the dashbord.config
But I just thought I would mention it.
When I look in the Manual Install package, the files isn't present
So either it is a leftover from old times, or the files is actually missing.
Best Regard
Kristoffer
Comment author was deleted
Looks like you are missing some usercontrols, but they aren't coming from contour, think it's from the cws package
Hey Tim
