  • Danny Winbourne 33 posts 54 karma points
    Oct 06, 2011 @ 17:12
    Danny Winbourne
    Get all submitted records in code (not XLST)
    what is the easiest way to get all submitted records into a dataset of sorts?
    In XLST, you can use  umbraco.contour:GetRecordsFromForm but, I can't find how/where to use this in code?
    I have the following code, which does work, but I would rather fetch just the records for my specific form.
    Cheers in advanced,
    Danny
                Umbraco.Forms.Data.Storage.RecordStorage storage = new Umbraco.Forms.Data.Storage.RecordStorage();
             var allRecords = storage.GetAllRecords();
                List<Record> pollAnswers = new List<Record>();
                foreach (var record in allRecords)
                    if (record.Form == new Guid(activePoll))
                        pollAnswers.Add(record);
  • Comment author was deleted
    Oct 06, 2011 @ 17:17
    Hi Danny,
    Take a look at this: http://www.nibble.be/?p=102
    Wich are basicly some dynamic objects you can use, should make it easy
    Oct 06, 2011 @ 17:28
    Danny Winbourne
    Hi Tim,
    Thanks for the quick response:
    ok, so I've tried:
                foreach (dynamic record in Library.GetRecordsFromForm(activePoll))
                    string foo = record.Name;
    it only loops once (I have 2 responses so far), and 'foo' is getting set to "uformrecords"
    Am I missing anything?
    Edit: I am doing this in the code-behind of a usercontrol, and not a cshtml file, so I can't use the razor markup.
    Oct 06, 2011 @ 18:41
    Danny Winbourne
    Ok, Sorted now.
    I hadn't downloaded the dll (DOH!) and was using a different library object.
    Cheers
    Danny
    Oct 07, 2011 @ 09:50
    great, glad it's working now
