    Oct 18, 2011 @ 14:24
    Anthony Candaele
    regular expression for valid email is case-sensitive
    I discovered that the regular expression for the email-field in the contact form template is case-sensitive
    email formats like this Name.Surname@Domain.be are considered invalid while the same email address but spelled without capitols is considered valid: name.surname@domain.be
    I tried to solve this by configuring another regular expression : [a-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[a-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[a-z0-9](?:[a-z0-9-]*[a-z0-9])?\.)+[a-z0-9](?:[a-z0-9-]*[a-z0-9])?
    But the result is the same, email addresses that are a mixture of small and capitol letters are considered invalid.
    How can I solve this?
    Thanks for your help,
    Anthony Candaele
    Belgium
  • Rodion Novoselov 694 posts 859 karma points
    Oct 18, 2011 @ 14:32
    Rodion Novoselov
    Hi. Probably the "(?i...)" construct would help. Just embrace your whole expression with round brackets "()" and append "?i" right after the first one.
    http://msdn.microsoft.com/en-us/library/yd1hzczs.aspx#Case
    Oct 18, 2011 @ 14:47
    Anthony Candaele
    Hi Rodion,
    I tried to add this to regular expression setting of the email field, but it doesn't work. All fields under the email field are not rendered anymore.
    thanks for your help,
    Anthony
    Oct 18, 2011 @ 15:41
    Tom Fulton
    4
    Here's one I've used in the past that works for upper/lowercase:  ^[_a-zA-Z0-9-]+(\.[_a-zA-Z0-9-]+)*@[a-zA-Z0-9-]+(\.[a-zA-Z0-9-]+)*(\.[a-zA-Z]{2,4})$
    -Tom
    Oct 18, 2011 @ 15:44
    Anthony Candaele
    Thanks Tom,
    It works, you rock :)
    greetings,
    Anthony
  • Wessel Spoelder 3 posts 26 karma points
    May 12, 2013 @ 09:50
    Wessel Spoelder
    2
    Thanks Tom, Was looking for that as well.
    I changed the part to check the top-level-domain however, to let the (relatively new) .museum top level domain pass.
    ^[_a-zA-Z0-9-]+(\.[_a-zA-Z0-9-]+)*@[a-zA-Z0-9-]+(\.[a-zA-Z0-9-]+)*(\.[a-zA-Z]{2,6})$
