  • Peter Drayton 29 posts 49 karma points
    Oct 26, 2011 @ 16:15
    Peter Drayton
    Added a Custom Prevalue Type, but it won't save.
    I have created a Custom Prevalue Type based on http://www.nibble.be/?p=86
        public class GetValuesFromMailChimp : FieldPreValueSourceType
            public GetValuesFromMailChimp()
                this.Id = new Guid("35C2053E-CBF7-4793-B27C-6E97B7671A2D");
                this.Name = "Get values from MailChimp";
                this.Description = "Getting values from MailChimp";
            public override List<PreValue> GetPreValues(Field field)
                List<PreValue> result = new List<PreValue>();
                try
                    int sort = 0;
                    string[] values = GetListSegments();
                    foreach (string value in values)
                        if (!string.IsNullOrEmpty(value.Trim()))
                            PreValue pv = new PreValue();
                            pv.Id = sort;
                            pv.Value = value;
                            if (field != null)
                                pv.Field = field.Id;
                            pv.SortOrder = sort;
                            result.Add(pv);
                            sort++;
                catch (Exception ex)
                    Umbraco.Forms.Data.LogHelper.Error(
                        "Get values from MailChimp: " + ex.ToString());
                return result;
            public override List<Exception> ValidateSettings()
                List<Exception> exs = new List<Exception>();
                    exs.Add(new Exception("No data from MailChimp"));
                return exs;
           public string[] GetListSegments()
                string strMailChimpURL = ConfigurationManager.AppSettings.Get(0);
                string strMailChimpAPIKey = ConfigurationManager.AppSettings.Get(1);
                string strMailChimpListID = ConfigurationManager.AppSettings.Get(2);
                string strMethod = "listInterestGroupings";
                MailChimpAPIRequest myPost = new MailChimpAPIRequest(strMailChimpURL, strMethod);
                myPost.Add("output", "xml");
                myPost.Add("apikey", strMailChimpAPIKey);
                myPost.Add("id", strMailChimpListID);
                string strMailChimpResponse = myPost.GetResponse();
                System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
                doc.LoadXml(strMailChimpResponse);
                XmlNodeList nodes = doc.SelectNodes("//groups/struct");
                string strTest = "";
                foreach (XmlNode node in nodes)
                    strTest = strTest + node["name"].InnerText + "|";
                string[] selectedValues = strTest.Split("|".ToCharArray(), StringSplitOptions.RemoveEmptyEntries);
                return selectedValues;
    When I select it from the Type dropdown, the Preview works fine.
    But when I click on SAVE, it says there is a problem with the Settings?
    Any help much appreciated.
    Oct 26, 2011 @ 22:28
    Hi Peter
    Could you perhaps post the message you're getting when you're trying to save the selected value? :)
    Dec 09, 2011 @ 12:19
    Peter Drayton
    Managed to fix it.
    Many thanks,
    Peter.
  • Shaun 248 posts 475 karma points
    Aug 01, 2012 @ 15:50
    Shaun
    Out of interest, can you remember the cause of the problem? I'm seeing the same thing with one I've created. any prevalue created using the default options stores correctly tho.
  • AnandBhopale 54 posts 172 karma points
    Apr 20, 2021 @ 08:02
    AnandBhopale
    What was the fix ? I am facing same problem.
