  • Simon steed 378 posts 700 karma points
    Oct 27, 2011 @ 11:51
    Simon steed
    Contour records randomly swapping over
    Strange one this. I've got a form with a Name and Email field setup. This gets submitted into Contour and then the page redirects to my user control page with the recordid as a query string param.
    So far so good. Now I am trying to access the submitted data based upon the recordid so I pass into the following method:
    public string ConvertRecord(string recordID)
                // for testing only
                //recordID = "bf986387-566d-4743-aa78-6bbaacaeb59f";
                if (recordID != "")
                    RecordStorage rs = new RecordStorage();
                    Record r = rs.GetRecord(new Guid(recordID));
                    RecordsViewer viewer = new RecordsViewer();
                    XmlNode xml =  viewer.GetSingleXmlRecord(r, new System.Xml.XmlDocument());
                    string email = "";
                    string name = "";
                    foreach (KeyValuePair<System.Guid, Umbraco.Forms.Core.RecordField> field in r.RecordFields)
                        if(email == string.Empty)
                            email = field.Value.Values[0].ToString();
                        else
                            name = field.Value.Values[0].ToString();
                    return name + "," + email;
                return string.Empty;
    What it should do is give me a string in the format "simon steed,me@my.com".
    The problem is sometimes it does, sometimes it doesnt. I am getting strange things like the email and name are swapped around. How can I stop this or is there a better way to get this data?
    Cheers
    Si
    Oct 31, 2011 @ 10:09
    Simon steed
    Nobody tried doing anything like this before?
  • Comment author was deleted
    Oct 31, 2011 @ 10:20
    And does the data get stored properly or also getting the swap effect there?
    Oct 31, 2011 @ 10:22
    Think you should just add an additional check to get the correct field first (based on the caption)... since now it's just based on the order
    Oct 31, 2011 @ 10:27
    Simon steed
    Hi Tim - Data seems to be stored correctly so not worried there, just randomly returns alternate data on different calls to get the record.
    I was originally wondering if there was a better way to get at the data, I guess i'm using the correct methods then?
    I'll try adding some additional logic, cheers :-)
