The most recent updates to Contour 1.1.9 - 1.1.11 say that they work in .NET 3.5.
I assume then that if I'm using .NET 4.0 that the latest version that I can install is 1.1.8. Is that correct?
Comment author was deleted
Well if you are running .net 4 you can just use the latest version...
The latest version being 1.1.11 or 1.1.8?
Contour 1.1.11
