Problems inserting Contour Macro inside <p></p> in RTE
I am having problems inserting a Umbraco Contour Macro with a form inside a already existing <p></p> tag in the RTE.
The only way to have it properly inserted is to do it outside the <p> tag.
For example, lets say that you write a textline inside the RTE first, and then hits Enter. Then the RTE automaticly inserts i new blank line of <p> </p>. And when my client then tries to insert the macro and then saves the document, the macro is gone!
We are using umbraco v 4.7.0 (Assembly version: 1.0.4090.21631) and Umbraco Contour 1.1.9.
//kalle
After doing some further testing, it seems that this only apply to Internet Explorer.
It works just fine in Chrome and Firefox.
//kalle
A quick fix to make it work in Internet Explorer is to hit space before inserting the macro.
