I've just created my first custom field type and uploaded the dll to the server however it is not currently available for selection. I followed the developer docs and a copy of my class can be seen below - did I miss something obvious?
namespace ProlificNotion.Umbraco.Contour.FieldTypes
using System;
using System.Globalization;
using System.Web.UI.WebControls;
using global::Umbraco.Forms.Core;
/// <summary>
/// Defines the CountryList FieldType for Umbraco Contour
/// </summary>
public class CountryDropDownList : FieldType
/// <summary>
/// The dropdown list control
/// </summary>
private readonly DropDownList ddl;
/// <summary>
/// Initializes a new instance of the <see cref="CountryDropDownList"/> class.
/// </summary>
public CountryDropDownList()
this.Id = new Guid("35EF2032-6F72-4C00-9515-2D93C27AA574");
this.Name = "Country List";
this.Description = "Renders an HTML select box with a list of countries";
this.Icon = "icon_field.gif";
this.DataType = FieldDataType.String;
this.ddl = new DropDownList();
this.FillWithISOCountries(this.ddl, CultureInfo.InvariantCulture);
/// <summary>
/// Gets or sets the editor.
/// </summary>
/// <value>
/// The editor.
/// </value>
public override WebControl Editor
get
return this.ddl;
set
base.Editor = value;
/// <summary>
/// Renders the preview.
/// </summary>
/// <returns>A string with the markup to render in the preview</returns>
public override string RenderPreview()
return "<select><option>United Kingdom</option></select>";
/// <summary>
/// Renders the preview with prevalues.
/// </summary>
/// <param name="prevalues">The prevalues.</param>
public override string RenderPreviewWithPrevalues(List<object> prevalues)
return this.RenderPreview();
/// <summary>
/// Populates the list control with countries as given by ISO 4217.
/// </summary>
/// <param name="ctrl">The list control to populate.</param>
/// <param name="selectedCulture">The selected culture.</param>
private void FillWithISOCountries(ListControl ctrl, CultureInfo selectedCulture)
foreach (var cultureInfo in CultureInfo.GetCultures(CultureTypes.SpecificCultures))
var regionInfo = new RegionInfo(cultureInfo.LCID);
if (ctrl.Items.FindByValue(regionInfo.TwoLetterISORegionName) == null)
ctrl.Items.Add(new ListItem(regionInfo.EnglishName, regionInfo.TwoLetterISORegionName));
var currentRegionInfo = new RegionInfo(selectedCulture.LCID);
// Default the selection to the current cultures country
if (ctrl.Items.FindByValue(currentRegionInfo.TwoLetterISORegionName) != null)
ctrl.Items.FindByValue(currentRegionInfo.TwoLetterISORegionName).Selected = true;
Custom Fiedld Type Not Appearing in DropDown
namespace ProlificNotion.Umbraco.Contour.FieldTypes { using System; using System.Collections.Generic; using System.Globalization; using System.Web.UI.WebControls; using global::Umbraco.Forms.Core; /// <summary> /// Defines the CountryList FieldType for Umbraco Contour /// </summary> public class CountryDropDownList : FieldType { /// <summary> /// The dropdown list control /// </summary> private readonly DropDownList ddl; /// <summary> /// Initializes a new instance of the <see cref="CountryDropDownList"/> class. /// </summary> public CountryDropDownList() { this.Id = new Guid("35EF2032-6F72-4C00-9515-2D93C27AA574"); this.Name = "Country List"; this.Description = "Renders an HTML select box with a list of countries"; this.Icon = "icon_field.gif"; this.DataType = FieldDataType.String; this.ddl = new DropDownList(); this.FillWithISOCountries(this.ddl, CultureInfo.InvariantCulture); } /// <summary> /// Gets or sets the editor. /// </summary> /// <value> /// The editor. /// </value> public override WebControl Editor { get { return this.ddl; } set { base.Editor = value; } } /// <summary> /// Renders the preview. /// </summary> /// <returns>A string with the markup to render in the preview</returns> public override string RenderPreview() { return "<select><option>United Kingdom</option></select>"; } /// <summary> /// Renders the preview with prevalues. /// </summary> /// <param name="prevalues">The prevalues.</param> /// <returns>A string with the markup to render in the preview</returns> public override string RenderPreviewWithPrevalues(List<object> prevalues) { return this.RenderPreview(); } /// <summary> /// Populates the list control with countries as given by ISO 4217. /// </summary> /// <param name="ctrl">The list control to populate.</param> /// <param name="selectedCulture">The selected culture.</param> private void FillWithISOCountries(ListControl ctrl, CultureInfo selectedCulture) { foreach (var cultureInfo in CultureInfo.GetCultures(CultureTypes.SpecificCultures)) { var regionInfo = new RegionInfo(cultureInfo.LCID); if (ctrl.Items.FindByValue(regionInfo.TwoLetterISORegionName) == null) { ctrl.Items.Add(new ListItem(regionInfo.EnglishName, regionInfo.TwoLetterISORegionName)); } } var currentRegionInfo = new RegionInfo(selectedCulture.LCID); // Default the selection to the current cultures country if (ctrl.Items.FindByValue(currentRegionInfo.TwoLetterISORegionName) != null) { ctrl.Items.FindByValue(currentRegionInfo.TwoLetterISORegionName).Selected = true; } } } }Hi, I'm facing exactly the same problem now. Can you please share how you solved?
