I am having problems displaying form entries for 2 of my forms on a client website. i have about 9 different forms and the two with the most entries, i of the forms has got 243 entries and it will let me view up to 100 entries per page and the other 1 has got 720 entries and it will only diplay 10 entries at a time only. if i select more that 10 entries on the last form it just hangs on processing and eventual doesnt diplay anything same with the first one if i when i select to view 500 it hangs. any kind of help is welcome as my client is running a competion using the forms and need to sort the forms in order to pick the prizes.
yes i am running the latest version as well couldnt even see any of the entries before then i upgraded to the latest one and can only view the 10 now and also when i try to export it will only allow me the 10 i am viewing as well and when i select to view all of the entries it fails to export them
Contour form entries (possible bug)
Comment author was deleted
And does the export function or also suffering from the same bug?
There have been some performance fixes so make sure you are running the latest version
this seems to have been fixed in the latest version of contour Contour_1.1.13.2.
