  • Seth Niemuth 275 posts 397 karma points
    Nov 25, 2011 @ 16:05
    Seth Niemuth
    BUG: Datasource with SQL Database with Datetime will not save into database
    I have a form with a datasource of a SQL Database table. There are no foreign keys on the table. There are 2 datetime items in the table. When I save the form, it does not get saved into the database. There is no error given. It just does not save into the database. However, if I do not include the 2 datetime fields in the form, it saves into the database just fine. I don't know if this is also possibly a culture problem as I am using EN-gb.
    .NET 4
    Umbraco 4.7.1
    Contour 1.1.11
    Here is a copy of my sql script to create the database table:
    To recreate just use this table as a datasource for a form and then fill out the form and it will not save into the database.
    CREATE TABLE [dbo].[ClubOrder](
    [Id] [int] IDENTITY(1,1) NOT NULL,
    [Title] [nvarchar](255) NOT NULL,
    [FirstName] [nvarchar](255) NOT NULL,
    [Surname] [nvarchar](255) NOT NULL,
    [Address1] [nvarchar](255) NOT NULL,
    [Address2] [nvarchar](255) NULL,
    [City] [nvarchar](255) NOT NULL,
    [State] [nvarchar](255) NOT NULL,
    [Postcode] [nvarchar](255) NOT NULL,
    [Dob] [datetime] NOT NULL,
    [PaymentStatus] [nvarchar](255) NULL,
    [Telephone] [nvarchar](255) NOT NULL,
    [Email] [nvarchar](255) NOT NULL,
    [TwitterUsername] [nvarchar](255) NULL,
    [DateOfNextStay] [datetime] NULL,
    [Interests] [nvarchar](255) NULL,
    [OtherInterests] [nvarchar](255) NULL,
    [Amount] [decimal](18, 2) NULL
    PRIMARY KEY (Id))
    GO
    Nov 25, 2011 @ 16:07
    Seth Niemuth
    Forgot to mention, I am using SQL Server 2005.
    Nov 29, 2011 @ 12:45
    Seth Niemuth
    Does the datetime work for anyone with a SQL Database source? If so, what version of SQL server are you using?
    Nov 30, 2011 @ 15:56
    Seth Niemuth
    Has anyone tried to use the SQL Database as a source on a contour form?
