  • Douglas Ludlow 210 posts 366 karma points
    Dec 05, 2011 @ 22:52
    Douglas Ludlow
    Autofilling a field with another field's value using Contour
    Is it possible to fill a field with the value of another field?
    Example: I have a "firstname" field and a "lastname" field and a "fullname" hidden field. I would like to populate "fullname" with a concatenation of first and last.
    I was trying to do this with the bracket syntax (I tried "{firstname} {lastname}", "[@firstname] [@lastname]", and "[%firstname] [%lastname]"), but it appears that the commands are evaluated before the page is rendered, not on submit.
    Any tips or suggestions? Or any other approaches?
    If there is any way to put in a feature request for Contour, I'd request parsing the curly brace syntax after submission.
    Dec 06, 2011 @ 00:49
    Douglas Ludlow
    The only options I came up with were to make the changes in a custom workflow, or add some jQuery. I decided on the latter because it was easiest:
    $(document).ready(function() {
    if($('.fullname input[type="hidden"]').length > 0) { //if the fullname hidden field is on the form
    $('.firstname input, .lastname input').blur(function() {
    $('.fullname input[type="hidden"]').val($('.firstname input').val() + ' ' + $('.lastname input').val());
