All forms fields are blank after upgrade/downgrade
i downgrade from 1.1.11 to 1.1.8 to solve one of my workflow problem. But now all my forms fields are blank. Is there a step that I missed ? Please help. Thanks!
I am running 4.7.1 and recently upgrade contour to 1.1.11 and my workflow stopped working (http://our.umbraco.org/forum/umbraco-pro/contour/26518-Workflow-stops-working-after-upgrade). Since no one replied that question i ask from previous post, i tried to downgrade the contour verstion to 1.1.8 and it worked just fine. I chose 1.1.8 because i notice the .NET 4.0 was in the description of the script and I am currently using .NET 4.0 to compile the workflow's dll. I believe contour's latest (1.1.11) is using .NET 3.5. Is there a way around to use 1.1.11 but for .NET 4.0 ? Please advice.
And yes, as soon as I install 1.1.10 or 1.1.11 on top of 1.1.8, ALL forms fields are back in the contour admin display.
yes, contour forms will normally work but the workflow dll i've been using, has stopped working. it's something about contour 1.1.11 that specifically target .NET 3.5
perhaps, you guys should throw a quick contour 1.1.12 that support .NET 4.0 to resolve this ? because ANY contour version that using .NET 4.0 works just fine with my workflow dll
correction: ALL contour forms that do not use my workflow are working just fine with the version 1.1.11 but those that has been using my workflow aren't
correction: all the fields in all my forms are gone.
Comment author was deleted
Hi what version of umbraco are you running? If you are running 4.7.1 you need at least contour 1.1.10 due to a jquery update in 4.7.1
Hi Tim,
Thanks!
Sure Contour should work for .net 4.0
please help
