    Dec 07, 2011 @ 18:25
    Dave Woestenborghs
    Contour provider for courier not working
    I installed the latest version of contour & courier and dropped the dll found on http://contourprovcourier.codeplex.com/ in my bin folder
    I don't see the courier option on the contour forms
    Am i missing something ?
    Dave
  • Per Ploug 865 posts 3491 karma points MVP admin
    Dec 07, 2011 @ 19:47
    Per Ploug
    Codeplex project is out of date, get it from our instead:
    http://our.umbraco.org/projects/developer-tools/courier-contrib
    Dec 08, 2011 @ 09:27
    Dave Woestenborghs
    Yep..Tim pointed me to that one on twitter
    Dec 15, 2011 @ 10:36
    Dave Woestenborghs
    I noticed that additional setting DefaultValue doesn't get transfered with courier. Where can I report it as bug ?
  • Comment author was deleted
    Dec 15, 2011 @ 11:16
    Hey, just use the courier contrib project on codeplex since that has the latest source
    Issue tracker is here: http://couriercontrib.codeplex.com/workitem/list/basic
    Dec 15, 2011 @ 11:21
    Dave Woestenborghs
    Hi Tim,
    Codeplex has no download. And the source code doens't contain the contour stuff so far as I can see.
    issue is created : http://couriercontrib.codeplex.com/workitem/1
  • Martin Griffiths 826 posts 1269 karma points c-trib
    Dec 05, 2012 @ 13:46
    Martin Griffiths
    Sorry to post here but it has contributions from Per and Tim, which mean I have half a chance of a quick reply :-)
    I'm having problems getting locallinks from within tinyMCE to transfer with Courier. More specifically the locallinks, link to a media type containing a PDF file. The link appears on live but 404s on the media item, so it's not transferring the media item.
    Have I missed a config entry specifically for PDFs?
    I'm using the Umbraco 4.11.1 and Courier nightlies (2.7.3.xxxxx)
    Martin
  • Laurence Gillian 600 posts 1219 karma points
    Jun 24, 2013 @ 12:54
    Laurence Gillian
    I'm trying to track down which files to use to allow Courier (2.7+) to transfer Contour forms.
    Any help would be lovely, Lau
    Jun 24, 2013 @ 12:57
    Think this is the latest one http://our.umbraco.org/projects/developer-tools/courier-contrib but pretty old, needs an update for some new stuff added in Contour 3
    Jul 02, 2013 @ 12:30
    Laurence Gillian
    Does that mean it will work for Contour 3, or I should hold off before it's officially supported.
    Any idea how long that might be? Thanks Tim :) Lau
    Jul 02, 2013 @ 12:34
    Laurence Gillian
    P.s I've yet to install Contour 3, but it looks like lots of the things that drove me nuts are not there any more! Mmmmm folders :) Super sexy, Ta - Lau
  • Maneesh 13 posts 33 karma points
    Jun 01, 2015 @ 06:53
    Maneesh
    Hi All,
    I have the problem with umbraco courier.Whenever i transfer any media file like pdf,doc,xls(except image files .gif,.png,.jpeg) from staging to live(destination environment), it doesnot transferring the media files.That means, the content nodes are getting transferred, but the files like pdf,doc,xls included with in that page is not getting transferred.
    But there is not having an issue with image files as I mentioned above.
    The umbraco version Using is : 4.0.2.1
    The courier vesion using is : 1.3
    Could anyone please suggest an idea about why this is happening?
    Also, please suggest the solution for fixing the same.
