  • Stephanie 39 posts 101 karma points
    Jan 05, 2012 @ 16:55
    Stephanie
    IE dying on request.GetResponse()
    I'm having an issue where the following code is working perfect in Chrome and FF but is dying on the bold/italic line in IE.  No error is thrown that I can tell, I have a try catch block that is printing to a text file any errors that are thrown.  This is a custom workflow for contour that adds a new contact to Constant Contact. The address variable is "https://api.constantcontact.com/ws/customers/[username]/contacts.  The contentType is "application/atom+xml".  The requestMethod is "POST".  The data is XML as shown below the code.  One thing I feel I should mention is that the username is an email address.  I'm assuming that this should be URL encoded.
    HttpWebRequest request = (HttpWebRequest)WebRequest.Create(address);
                request.Credentials = CreateCredentialCache(address, authenticationData);
                request.Method = requestMethod;
                request.ContentType = contentType;
                request.PreAuthenticate = true;
                request.ContentLength = data.Length;
                Stream stream = request.GetRequestStream();
                stream.Write(data, 0, data.Length);
                Stream responseStream = Stream.Null;
                try
     HttpWebResponse response = (HttpWebResponse)request.GetResponse();
                    Console.WriteLine(String.Format(CultureInfo.InvariantCulture,
                                                    "Method {0}, response description: {1}", request.Method,
                                                    response.StatusDescription));
                    if (response.StatusCode == HttpStatusCode.NoContent)
                        return Stream.Null;
                    responseStream = response.GetResponseStream();
                    MemoryStream memoryStream = ReadResponseStream(responseStream);
                    return memoryStream;
                catch (Exception ex)
                    Logging.LogError("GetResponseStream: " + ex.Message);
                finally
                    stream.Close();
                    responseStream.Close();
                return Stream.Null;
    <entry xmlns="http://www.w3.org/2005/Atom">
        <title type="text"></title>
        <updated>2008-07-23T14:21:06.407Z</updated>
        <author></author>
        <id>data:,none</id>
        <summary type="text">Contact</summary>
        <content type="application/vnd.ctct+xml">
            <Contact xmlns="http://ws.constantcontact.com/ns/1.0/">
                <EmailAddress>email@email.com</EmailAddress>
                <FirstName>s</FirstName>
                <MiddleName></MiddleName>
                <LastName>j</LastName>
                <HomePhone>7</HomePhone>
                <Addr1></Addr1>
                <Addr2></Addr2>
                <Addr3></Addr3>
                <City></City>
                <StateCode></StateCode>
                <StateName></StateName>
                <PostalCode></PostalCode>
                <SubPostalCode></SubPostalCode>
                <CountryCode></CountryCode>
                <CompanyName>m</CompanyName>
                <JobTitle>i</JobTitle>
                <WorkPhone></WorkPhone>
                <EmailType>HTML</EmailType>
                <OptInSource>ACTION_BY_CONTACT</OptInSource>
                <Note></Note>
                <CustomField1></CustomField1>
                <CustomField2></CustomField2>
                <CustomField3></CustomField3>
                <CustomField4></CustomField4>
                <CustomField5></CustomField5>
                <CustomField6></CustomField6>
                <CustomField7></CustomField7>
                <CustomField8></CustomField8>
                <CustomField9></CustomField9>
                <CustomField10></CustomField10>
                <CustomField11></CustomField11>
                <CustomField12></CustomField12>
                <CustomField13></CustomField13>
                <CustomField14></CustomField14>
                <CustomField15></CustomField15>
                <ContactLists>
                    <ContactList id="https://api.constantcontact.com/ws/customers/[username]/lists/37"/>
                    <ContactList id="https://api.constantcontact.com/ws/customers/[username]/lists/39"/>
                </ContactLists>
            </Contact>
        </content>
    </entry>
