I could not get it to work with MySQL, even though our site was running on MySQL, I reported this in November last year and Casey Neehouse said he would get back to me about this on 31/11/2011 but didn't.
Contour doesn't generate an error when its installed on a MySQL Umbraco. Contour doesn't support the MySQL used for Umbraco as a datasource. To use Contour as a datasource it must be configured as OLEDB, as your message states "Connects to any OLEDB supported Database Table and constructs a datasource from it" the only way to set up MySQL as OLEDB is using third party products from obscure sources.
If Umbraco can use MySQL without OLEDB why can't Contour do the same?
Is Contour compatible with MySQL?
Is Contour (full licensed version) compatible with MySQL?
Comment author was deleted
Yup it runs on MySQL so it should just work if you have umbraco running on MySQL and install Contour
Tim
Lou
Hey Lou what version of MySQL are you running + do you remember what failed during the installation of Contour?
Tim
Lou
Ah yes it's the specific datasource that doesn't work but the basic Contour functionalitiies should work fine
