  • Pat 56 posts 147 karma points
    Jan 16, 2012 @ 16:17
    Pat
    Issues with form design
    Hey,
    I need to make a basic form, where there are just 4 input text fields, each with a label next to them, and a submit button underneath.
    Sort of like this:
    Name ........... Telephone .............
    Email ............ Company ..............
                  SUBMIT
    I have no idea how to though! The basic form is just all under each other, and looks quite nasty.
  • Comment author was deleted
    Jan 16, 2012 @ 16:19
    Hey,
    You should be able to get the result you want by styling the form with css, so simply disable the default stylesheet and take full control
    Jan 16, 2012 @ 16:25
    Pat
    Hi Tim,
    I thought that'd be what I would have to do, but I can't seem to locate a CSS file for it.
  • Douglas Ludlow 210 posts 366 karma points
    Jan 16, 2012 @ 18:33
    Douglas Ludlow
    You just need to add a reference to the stylesheet (or add <style> tags) in the head of the template that the form is being used in. View the source of the page with the form to figure out the html/class/id structure of the form and then go from there as far as styling it.
    The default template resides at ~/umbraco/plugins/umbracoContour/css/defaultform.css. But don't edit it. Do as Tim suggests and disable it in the actual form settings (check "Disable default stylesheet') and then create/modify your own stylesheet. I provide the path for it here so that you can see how the form is styled by default as a reference.
  • bev0 39 posts 59 karma points
    Jan 16, 2012 @ 21:34
    bev0
    Go to your contour form, hit Setting tab, put a check in the "Disable default stylesheet" checkbox.
    Then in your template, create a css file that would style those form fields.
    Jan 17, 2012 @ 02:53
    Pat
    Hi, I have disabled the default one.
    I have found the CSS, made a copy of it and had a look through it, seems a bit confusing. Am used to CSS, but defining where the different textfields go is confusing me.
    Any hints etc would be appreciated.
    Jan 17, 2012 @ 16:06
    Douglas Ludlow
    You'd probably want to do something with floats or absolute positioning.
    For floats, have a look at http://css.maxdesign.com.au/floatutorial/. Take a look at tutorial 4.
