1) i try to use a custom events for contour like i did for document or page..
this code is not actually what i am trying to do but i write it for testing and it is not work for me.
i am using contor 1.1.12
this is the code: ( outer class )
using System; using System.Collections.Generic; using System.Linq; using System.Text; using Umbraco.Forms.Core; using Umbraco.Forms.Core.Services; using umbraco.cms.businesslogic.web; using umbraco.BusinessLogic;
namespace customEvents { public class FormEvent : umbraco.BusinessLogic.ApplicationBase { public void formsEvent() { RecordService.RecordSubmitted+=new EventHandler<RecordEventArgs>(RecordService_RecordSubmitted); RecordService.RecordApproved += new EventHandler<RecordEventArgs>(RecordService_RecordApproved); }
contour custom events
hello everyone.
i have 2 questions.
2 ) what i am actually triyng to do is to check some field - lets say : coupon code.
and then change another field - lets say : description of discount.
( this is for the site-manager when export the entries )
if there is another/better way to do it i would i'd love to hear.
thanks in advacne.
Comment author was deleted
Hey could you share some more details on what you want to do that way I'l be able to point you in the correct direction
Is it just changing the value of a certain field depending on an other field when the record has been submitted?
Hii tim,
yes. that what i am trying to do.
actually i managed to do it but i will be glad if you write here what do you think is the right way to do it.
thanks in advance.
