  • Ivan 139 posts 302 karma points
    Feb 14, 2012 @ 13:02
    Ivan
    Form dropdown field does not apply default value
    Hi.
    I am working on a member profile form where members can update their data at the frontend.
    For one of the fields i have created a new "Prevalued Sources" of type "Umbraco Documents" and assigned it to a "dropdown" field. Therefore i have assigned {member.location} as default.value.
    I've got two problems:
    1. Using "Member Profile" form dropdown list field i can update member profile's location but whenever i load the form, dropdown list is empty (don't remember selected value).
    2. I don't get rendered grandchildren content nodes:
      Content node 1
       -- Content node 11
       -- Content node 12
      Content node 2
      Content node 3
    I also tried with Ultimate Picker as "Prevalued Sources" with worse results.
    Any ideas how can i get it working using Contour?
    Thanks in advance!
    Ivan
    Dec 04, 2012 @ 14:39
    Dave Woestenborghs
    I actually have the same problem...so just bumping this thread
    Dec 05, 2012 @ 12:54
    Ivan
    Hi dawoe,
    Finally i created my own solution taking "Profile Editor Macro" source code as reference.
  • Comment author was deleted
    Dec 10, 2012 @ 13:17
    Looks like a bug, will add it to our issue tracker and take a look for the next maintenance release
