  • Ben McKean 272 posts 549 karma points
    Feb 16, 2012 @ 13:16
    Ben McKean
    Contour Unique Reference
    Is it possible using Contour to return a unique reference to the user once they've submitted the form, return it to them in an email and also log it in the database for that record?
    If so is this built in or would it require some customisation using the API?
    Ben
  • Comment author was deleted
    Feb 16, 2012 @ 13:51
    Well each record that is submitted as a unique id, is that sufficient?
    Feb 16, 2012 @ 13:54
    Ben McKean
    Hi Tim,
    Thanks for the reply.
    It take it thats a sequential unique ID from the DB? Is it relatively straight forward to get that once the form has been submitted and display it to the user or email it?
    I suppose ideally I'd want to save a random ID into the DB on each save and display that to the user so its not sequential
    Feb 16, 2012 @ 13:57
    Well it's a guid so not sequential, sure it should be pretty straigh forward to display it to the user, when you choose to send the user to a certain page after submitting the form (can be done on form settings) contour will post the record id to that page...
    Feb 16, 2012 @ 16:47
    Ben McKean
    Thanks Tim. Makese sense
