  • Simon Dingley 1474 posts 3451 karma points c-trib
    Feb 20, 2012 @ 13:00
    Simon Dingley
    Required Fields Depending on Options Selected in another field
    Is it possible in Contour to have required fields dependant on selections made in other form controls e.g. If "Other" is selected from a RadioButtonList then the "Other" textfield then becomes a required field? Or is it a case of having to implement some jQuery hacks to achieve this which I'd prefer to avoid as it's not that flexible.
