  • Fuji Kusaka 2203 posts 4220 karma points
    Feb 28, 2012 @ 12:43
    Fuji Kusaka
    Manual Approval not working
    Hi Guys,
    I have a comment form runing under v4.7.1 but I want all comments to be Approved before being visible on the website. Under my Setting Mode in contour section i have Manual Approval checked but still even Submitted Comments are visible.
    Somehow i changed the Xslt to
    <xsl:variable name="records" select="umbraco.contour:GetApprovedRecordsFromPage(@id)/uformrecord[state = 'Approved']"/>
    But nothing is showing up now!!!
    Any suggestions on this?
    //fuji
    Feb 28, 2012 @ 14:34
    Tom Fulton
    Hi Fuji,
    That should work, what does the rest of your XSLT look like?
    Are you maybe trying to select uformrecord in your for-each?  You won't need to since you are doing it above, ie
    <xsl:for-each select="$records">
    If that's not the case you can also try looking at the XML to make sure it's correct
    <textarea><xsl:copy-of select="$records"/></textarea>
    -Tom
    Feb 28, 2012 @ 18:18
    Fuji Kusaka
    Hey Tom,
    Its working, in my loop i was calling the uformrecord again so this was giving me all the records been submitted and Approved at same.
    Anyway here is the solution if someone needs it.
    <xsl:variable name="records" select="umbraco.contour:GetApprovedRecordsFromPage($currentPage/@id)/uformrecord[state = 'Approved']" />
    xsl:for-each>
    But thanks for pointing out.
    //fuji
