    Mar 01, 2012 @ 15:38
    Installation problem: Web.Config could not be updated
    Hi guys
    I just tried to install Contour (1.1.12) on a v4.7.1.1 instance of Umbraco.
    After installing I get this error:
    • web.config could not be updated +
      System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e)
    IUSR and Network service have full permissions...don't know if other users should be granted access?
    I suppose it's just a matter of updating the web.config manually but I'm unsure what and where to update.
    So what should I do to make sure everything is allright?
    Thanks.
  • Comment author was deleted
    Mar 01, 2012 @ 15:45
    It's outlined in the installation guide found on the contour project page
    But think the web.config changes are obsolete (was in case umb was running in a .net framework 2 app pool)
    So you should be all set, the only other update that might come in handy is updating the max json length (if you get a failed to save form error)
    http://our.umbraco.org/forum/umbraco-pro/contour/26112-Contour-'Failed-to-save-form'
    Mar 01, 2012 @ 15:58
    Thanks Tim!
