  • Nick Clapson 3 posts 23 karma points
    Mar 17, 2012 @ 15:17
    Nick Clapson
    Validating Checkboxes using JQuery
    Hi I'm a bit of newbie and have got stuck.
    I have contour form but I need to check if 3, and only 3 of a number of checkboxes have been selected.
    I would normally do this with JQuery but I can see a way of attaching this to the form elements in contour.
    What's the best way to do this contour seeing as it only does mandatory validation out of the box?
    Thanks for your help!
  • Comment author was deleted
    Mar 21, 2012 @ 08:45
    Hey,
    Well you can simply add some additional jquery to the template where you have your form...
