  • MK 429 posts 906 karma points
    Mar 27, 2012 @ 16:46
    MK
    default members values in forms
    Hi there,
    Thanks to nibble :http://www.nibble.be/?p=106 I'm able to insert member's details to the form so they would not need to retype it. However, if a user is not logged in he will see the default value I've inserted such as {member.name} and {member.email} etc.
    Is there a way to hide these values?
    Many thanks
    mkariti
  • Comment author was deleted
    Mar 27, 2012 @ 17:51
    Yeah it's a bug, will be solved in next maintenance release.
    Mar 27, 2012 @ 18:02
    MK
    Hi Tim,
    When will the next maintenance release be?
    Many thanks
    mkariti
    Mar 27, 2012 @ 18:04
    Should be in first half of April
    But will try to take a look at this one this week so you can upgrade to a work in progress version
    Mar 27, 2012 @ 18:14
    MK
    :D Many thank!
    How will I know about the new update?
    Cheers
    Apr 09, 2012 @ 08:41
    MK
    Hi Tim,
    Any news regarding this post?
    Many thanks
    mkariti
  • Chris McLaren 4 posts 25 karma points
    Jun 27, 2012 @ 12:47
    Chris McLaren
    Hello.  Any update on this?  I'm having the same issue.  Thanks.
    Jun 27, 2012 @ 13:31
    MK
    Im waiting for this one as well.
    Was off the project for the past few weeks but now Im back so....
    Aug 07, 2012 @ 10:50
    Hey,
    Sorry for the delay on this one, is fixed in current WIP version that you can find here: http://nightly.umbraco.org/Umbraco%20Contour/1.1.13%20WIP/ would be great if you could give it a test
    Aug 07, 2012 @ 14:28
    MK
    Hi Tim,
    Sweet! Will give it a try sometime this week.
    mkariti
    Aug 14, 2012 @ 10:13
    MK
    Hi Tim,
    Got the following error when trying the update package:
    Could not upload file
    System.Exception: Error unpacking extension... --->
    System.IO.FileNotFoundException: Could not find file
    'C:\inetpub\wwwroot\xxx.com\App_Data\dba13aa3-e83c-4002-ae2f-e2ff652ac3b2\package.xml'.
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path,
    FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options,
    SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) at System.IO.FileStream..ctor(String path,
    FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) at System.Xml.XmlUrlResolver.
    GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn) at System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver) at System.
    Threading.CompressedStack.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.
    ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.
    CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state) at System.Xml.XmlTextReaderImpl.
    OpenUrl() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
    at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at umbraco.cms.businesslogic.packager.Installer.
    LoadConfig(String tempDir) at umbraco.cms.businesslogic.packager.Installer.Import(String InputFile) --- End of inner exception stack trace ---
    at umbraco.cms.businesslogic.packager.Installer.Import(String InputFile) at umbraco.presentation.developer.packages.Installer.uploadFile(Object sender,
    EventArgs e)
    So I installed it again and it works like a charm!
    Cheers
    mkariti
